Are there any common issues on new dispatches, 2020 plate.
No start
No crank
Key fob stopped working
Ignition lights come on as normal
Fault codes:
ECU:
P0215:72 principle relay control
However I've seen that code also on vans running fine.
BSI:
U1f28:87 no comms with steering wheel switch module
(Although looking at the stalk and ring, the ring wiring goes behind the dash towards bsi so I don't think this is anything other than a module for the stalks as I understand some older ones have a SWCM under the column which receives signal).
Got two of these, same fault. One the alarm won't stop whinging though and the other not.
Main relay seems to work though as it feeds fuel pump relay which I can hear fuel pump activate with ignition key and see the feed to f11 f12 and f13 as it should.
Also pin 1 main live at ecu getting voltage.
I didn't get chance to check all voltage feeds but can't read ecu find, can read bsi and other major modules.
Can't see any tech bulletins relating to it. And did think about the fuse box BFRM but then surely I'd loose comms with bsi or ecu altogether.
