Peugeot 1.9 rocker cover gasket
Barney00731102012
Unread post by Barney00731102012 »
Hi All
I’m looking for some help the rubber Rocker cover gasket on our Peugeot 1.9td 2001 has started leaking, it had a new fitted 700miles ago. The new gasket was a Victor Reniz fitted to a new cylinder head and totally cleaned beforehand and yet it still leaked, so I’m looking for help on how to combat this. Has anyone else had this issue?
Any help would be greatly appreciated.
Oldpug
x 93
Re: Peugeot 1.9 rocker cover gasket
Unread post by Oldpug »
That’s very unusual? Normally those rubber cam over gaskets are fit and forget items.
I’ve fitted 100’s and never had issues.
Firstly are you sure the oil is coming from the gasket. If it is it may be due to the fixings not putting enough pressure on the rubber gasket. You say it’s had a new cylinder head? perhaps the cam over studs are different?
x 1987
Unread post by Stickyfinger »
Most common mistake is over tightening them.....
Barney00731102012
Hi
Thanks for your reply’s, ok I’ve got another new rubber gasket, two things firstly should I use any type of glue between the gasket and the Cylinder head? Secondly the Haynes manual says torque to 20nm which I did, and then the Brookland books says 6 ft lb. Any suggestions.
x 8294
Barney00731102012 wrote: 19 Jan 2025, 16:25 Hi
Use no sealant - just ensure the mating surfaces are spotlessly clean.
The torque setting is critical. Not too tight. 20Nm seems a bit excessive to me. There is a risk of warping if too tight. 6 ft lbs sounds about right. Too tight and you risk warping the cover.
Do up to 6 ft lb and if it still weeps, equally tighten just a bit tighter...
Barney00731102012
Removed leaking rubber rocker cover gasket today, yes torquing rocker bolts to 20nm is far to much when I removed the gasket the rocker had cut through the gasket hence leaking, so I’ve cleaned both rocker cover and cylinder so it’s spotless and fitted a new one and now torqued the 3 rocker cover bolts to 6 ft lbs / 8.5 nm and see if this now cures it. Oh yes and I’ve not used any jointing seal on the gasket.( Fingers crossed). Thanks for advice from other member it’s greatly appreciated 😀
x 8294
Pleased you found the root cause, let's hope all will now be good!
Barney00731102012
Just a quick update we’ve got to Scotland today after stopping in Wales and the Lake District for a couple of weeks, And would you believe it the rocker cover gasket has started to weep oil again. I thick at the moment I’m going to leave it until I’m back home in mid April as knowing luck I will make it worse, but god knows how to stop it. I think the best thing to do is throw the hot potato to Peugeot and let them sort it out.
x 1056
Unread post by wheeler »
How old is it? A Peugeot dealer will likely pull your pants down, i’d be tempted to remove, clean & re fit with a bit of RTV sealant. You shouldn’t have to on this type of gasket but if you have replaced it twice now its worth a shot.
Barney00731102012
To be honest I don’t really have a lot of faith in garages, never really had any joy with any, seems the job doesn’t get done properly or you end up paying through the nose for it, that’s just my personal experience. As I’m totally at the other end of the country to where we live I’m going to bare with it and see how it goes.
Barney00731102012
Hi All
We’ve travelling around Scotland for the last 6 weeks and still have a couple of month to go. I’ve been looking around for another rocker cover online as the gasket on are camper has started weeping again, I don’t want to tighten it down anymore as we are on the Isle of Unist at the moment and believe me there’s not a lot of choice in garages, Motor factors or anything else automotive. And the weather outside over the last couple of days you certainly wouldn’t go outside with a wig on either. Anyway if anyone can point me in the direction to locate another rocker cover please message me.
