Citroen c4 2011 auto
Bubblychick4068
New User
Unread post by Bubblychick4068 »
Hi all I recently had injectors cleaned new clamps put on and bolts and new fuel off pipe as an injector popped out and well had to be done car has driven fine for a week and was driving the first long journey today since was doing 50 and the engine light come on , hand break failure, gearbox fault light and service and esp light 8-[
Scanned it and came up with the following codes
DTC:P1641,Initialization faulty on the bank of injectors, or harness faulty
DTC:P0113,Temperature sensor at the air flowmeter
DTC:P2291,The rise in pressure in the injection rail is too slow on starting
DTC:U1213,CAN: One of the parameters present in a data stream sent by the ABS/ESP is invalid
ENGINE
DTC:U0415,Invalid data received - anti-lock brake system (ABS) control module
Any idea what could cause this at all kinda at my wits end :-(
