Hi all
I’ve just purchased a 2020 Citroen Relay which I’ll be converting into a camper. I’m looking at options for updating the radio so I can use CarPlay, and so far see the common approach is to install a Chinese or branded double din unit.
However, is it possible to instead retrofit the updated OEM unit from the 2023 model which includes CarPlay (DAIICHI D716AF-P)? This is actually cheaper than a branded alternative and would hopefully offer better integration - https://www.ebay.co.uk/itm/116420684170
For reference, my 2020 van has this factory unit installed - https://www.ebay.co.uk/itm/276710686264. If you check the photos of each unit, they both appear to have exactly the same connectors on the back.
How likely is it I can just drop the newer D716AF-P head unit into my van? Will anything need to be coded and if so what’s the best way to go about doing this?
Thanks in advance for any help!
Retrofit 2023 Relay head unit into 2020 Relay?
- x 6960
Re: Retrofit 2023 Relay head unit into 2020 Relay?
Can't advise you on this as it's a FIAT vehicle variant and uses Fiat components like the Head Unit. I can only advise on pure PSA vehicles with Citroen / Peugeot engines and parts.
What I can tell you though is that no, you can't just swap units, they are coded to the vehicle and in the case of Fiat variants require a Proxy Alignment with their diagnostics when introducing new equipment in order to pair it to the vehicle.
Relay
Thanks for your reply, I'll check out some Fiat-specific resourcesGiveMeABreak wrote: 14 Jan 2025, 12:17 Can't advise you on this as it's a FIAT vehicle variant and uses Fiat components like the Head Unit. I can only advise on pure PSA vehicles with Citroen / Peugeot engines and parts.
olusek53
Hi everyone, it's my first post here.
I also have the same question, I have 2018 Boxer with 7" sat nav unit, I'd like to upgrade it to android auto unit from the latest models, same part number DAIICHI D716AF-P
I found one unit on Ebay from Citronen and wondering if it will be plug and play to my Peugeo boxer?
Any advice? Or if not how to make it work?
