Boxer diagnostic woes :(
DaveS
Unread post by DaveS »
Hi all, hoping someone can point me in some direction here!
Vehicle is a 2.2 Boxer, 2015.
SO this all started when trying to align a new airbag ECU to my BSI. When connecting DiagBox to my vehicle, I get communication errors to every module apart from the BSI, ABS and ECM. Looking at the BSI parameter live data, I can see that all modules are connected and awake. They also disappear/re-appear if I pull the plug and reconnect, Does this confirm that all is well with at least the CAN lines? Should I perform resistance checks on each of these just incase?
Ive also disconnected all modules from the BSI, and just connected one with a previous com error, just to rule out a faulty module putting interference on the CAN network. No change.
Purchased a generic 1279 module off amazon and still no joy. Anyone ever had one of these modules DOA? Might be clutching at straws, but there is the option to grab a genuine PSA 1279 module, albeit for 245 quid almost.
Any other ideas?
Cheers!
x 1943
Re: Boxer diagnostic woes :(
Unread post by Paul-R »
What version of Diagbox are you running?
Is your interface a full chip type?
DaveS
Hi Paul,
Using DB 7.57
Interface is one of the VCX types from EasyDiagnostics. I'm not sure if these suffer with the same limitations as the cloned Lexia interfaces
