Reversing light problem on a citroen c1 mk2
Apm1274
Hi, The reversing light on my citroen c1 2015 mk2 doesn't work. I've changed the bulb, fuse and the reversing light switch. But it still doesn't work! Is it an electrical fault? Has anyone got any ideas what it could be?
- x 6945
Re: Reversing light problem on a citroen c1 mk2
Hi, you should also check the reversing switch on the gearbox, as this is what informs the vehicle you've selected reverse gear and that triggers the reversing light.
Apm1274
Hi Marc, I have changed the switch. But it still doesn't work.
