aftermarket bluetooth
adiopeto
Got my self a CD changer for the 2006 phase 2 Citroen c5 but I can figure out what screw is it held in by. My tolls are either too big, don't bite properly or too short to reach the screw. Second question is do I need to activate CD change, how to do it and can I bypas it due to lack of tools and diagnostics mashines.
adiopeto
Re: aftermarket bluetooth
The driver must be a t8 as I have seen online but what about the diagnostics. Any bypasses?
- x 1056
The CD changer does normally need enabled with decent diagnostics. occasionally they are already enabled, its worth plugging it in and trying it but more than likely will need programming, if its not already enabled there is no other way around it.
Once it's done you will be partying like its 1999
EDIT: The title says aftermarket Bluetooth, have i missed something?
adiopeto
Can you suggest diagnostics tools, tutorial or anything related to the to enabling it.wheeler wrote: 03 Jan 2025, 16:29 The CD changer does normally need enabled with decent diagnostics. occasionally they are already enabled, its worth plugging it in and trying it but more than likely will need programming, if its not already enabled there is no other way around it.
