Glass replacement
Satchiman
Glass replacement
Unread post by Satchiman »
RH front drivers side window smashed. Can’t get door panel off to replace glass. Can anyone tell me how to do this pls.
x 6946
Re: Glass replacement
Hi.
  • You may need to remove the triangular trim from the inside window corner.
  • You'll have to first remove the door grab trim (either side of the door grab strap) and the small square trim in the door aperture directly in line with the grab strap.
  • There should be 5 screws to be undone.
  • Then you should be able to gently pull away the door card which is held by p door trim clip / studs - but be wary of the cables for the door control pad (see below)
  • Once inside, carefully disconnect the connectors for the driver door control pad
You should then have access to determine what else if anything you need to remove.
