C4 CACTUS LIN Fault & Cruise control dropping out
EdMar
x 3
Unread post by EdMar »
Hi
I'm new to the forum,
I recent got a C4 Cactus with a niggling code.
Bsi U1F1B LIN Fault 21 is the most persistant code.
I'm no longer able to access servicebox after stellantis take over (no VAT number)
Could I possible request some wiring diagrams ?
Mainly LIN BUS relating to U1F1B code, BSI terminals ,
VIN : VF7**************[VIN obfuscated, can be read by forum staff] , sorry forgot to get production number
If possible would also like, Telematics Terminals. TouchScreen
Multimedia CAN.
Cruise control drops out occasionally, Vehicle speed signal code (didn't log number),
There is a worn suspension bus my be affecting ESP / Cruise.
ESP light not on when cruise drops out, also ESP off button not responding
Also U1F3E Absence of telematics comms, & U1F18 Touch screen not communicating on multimedia CAN.
Also on one start, no audio from radio was observed.
I am thinking a data comm problem in the BSI/Telematics/Touchscreen area
Is touch screen comms a requirement for Cruise control function ?
Thanks in advance
EdMar
x 3
Re: C4 CACTUS LIN Fault & Cruise control dropping out
I'm a bit further on with this,
Santa brought me a nice handheld scope fast enough to check CAN
There are issues with CAN network, think I know what it is
I will post more if I manage to confirm.
Wiring diagrams would help pls.
x 6950
Hi, sorry but I don't have any wiring diagrams for the Cactus, and we don't provide technical docs / wiring diagrams unless staff already have them.
Any issue with the ESP system and cruise control and any associated features like Hill Start Assist, descent control and such will be deactivated.
EdMar
x 3
Hi
Yes I am thinking that it is a message from an ESP related component possibly on a LIN BUS connection , that is not getting through to the ABS due to noisy CAN.
ESP button linked to BSi by LIN?
Codes can be misleading some times,
With out having the scenario which triggers the code, Hyundai manuals descibe what sets the code, but most codes range from lost in translation to down right obscure.
I'm thinking the code meaning may be closer
'Message from LIN connected component not reaching destination'
Noisy can not letting low priority button message though, is my working theory at the momemt.
Been prodding ESP button every few minuites & fails about 5% of the time.
Hope do a bit of reverse engineering on the CAN next week.
EdMar
x 3
Could I request the build sheet pls?
Also a parts look up , if convenient,
If there an ABS loom listed for cactus
Similar to this ebay one for C4
https://www.ebay.co.uk/itm/296774156227?
x 6950
Sure, build sheet:
Vehicle Characteristics
Vehicle familyC4 CACTUS
AS/RP N°14529 82 1 0105
Warranty Start Date23/09/2016
Engine serial number10 JBHA 0179657
OPB009V
BERe2*2007/46*0440*05
P4A9814183799
General Information
PRODUCT TYPEPASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPECITROEN
VEHICLE FAMILYC4 CACTUS
SILHOUETTE5-DOOR SALOON
TRIM LEVELHIGH MEDIUM
ENGINEDV6FD FAP DIESEL
TRANSMISSIONBVM5
PAINT TYPEMETALLIC LACQUER
BODY COLOURKTP - SHARK GREY PAINT
INTERIOR TRIM TYPECLOTH WARP AND WEFT CURITIBA "23"
UPHOLSTERY COLOUR"FR"
GEARBOX (CHARACTERISTICS)MANUAL GEARBOX BE4/5 O
CONVERSION GUIDANCEWITHOUT CONVERSION
DEFINITION TO FOLLOWINITIALE RANGE
ENGINE (TYPE)DV TYPE ENGINE
BADGEFAMILY BADGE
SPEEDOMETER DRIVEWITHOUT SPEEDOMETER RATIO
Fuel Supply-Engine
FUEL SUPPLYDIRECT EXCHANGER TURBO INJECTION
DIESEL FILTER WATER DETECTORWITHOUT DIESEL FILTER WATER DETECTOR
FUELDIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE)EURO 6.1 ENGINE EMISSION CONTROL
CAPACITY1600 CM3
CATALYTIC CONVERTER2-COMPONENT CATALYTIC CONVERTER LOWER FILTER 50PPM 30 GR
FUEL TANKFUEL TANK WITH LOCATING TAB
OPTIMISATION OF VEHICLE’S CONSUMPTIONNORMAL FUEL CONSUMPTION OPTIMISATION
COOLING MOTORRADIATOR TH : 18 - 21 DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATINGWITH HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE)POWER 73 KW - 254 NM
EOBD SELF-DIAGNOSIS SYSTEM"EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER
DEVICE (ANTIPOLLUTION)"EGR" EXHAUST GAS RECYCLING
VEHICLE TECHNICAL DEPOLLUTIONEURO 6.1 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTERWITH PARTICLE EMISSION FILTER
FAN1 AERO 2-SPEED 140W FAN WITH SCOOP
FUEL VAPOUR RETRIEVALWITHOUT PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANTMOUNTING BOSCH
TANK FILTERCITHOUT RESERVOIR FILTER
STOP AND STARTWITHOUT STOP AND START
Gearbox Transmission
TRANSMISSIONBVM5
FINAL DRIVE RATIOAXLE RATIO 19 X 72
WHEEL STYLE17" ALLOY WHEEL
SEAL, WHEEL ENDNOT AFFECTED
DIFFERENTIAL (GEARBOX)DIFFERENTIAL 77
RIM/TYRE SIZE17 INCH TYRE FITMENT
TYRE (SIZE, TYPE)205/50 R17 V NON REINFORCED TYRE
WHEELS FITTED6,5" RIM ROAD WHEELS
WHEEL (TYPE)ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATORINDIRECT TYRE UNDER-INFLATION DETECTION WITHOUT LOCATION
GEARBOX TYPEGEARBOX BE4R
Suspension-Steering-Brakes
ABSWITH ABS BRAKES
FRONT ANTI-ROLL BARFRONT ANTI-ROLL BAR DIAM 20
BRAKE TYPEVENTILATED FRONT DISCS/REAR DRUMS
STEERING WHEEL ANGLEWITH ABSOLUTE STEERING WHEEL ANGLE ESTIMATOR
SUSPENSIONNORMAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEMELECTRONIC STABILITY PROGRAM
BRAKE ASSOCIATED VARIANTESP TEVES MK100E
STEERING (OPERATION)ELECTRIC POWER STEERING
ELECTRIC STEERINGELECTRIC STEERING POWER 68 AMPERES
PEDAL BRACKET (TYPE)SIMPLE STANDARD PEDAL BRACKET
Body Fittings
TOWBARWITHOUT TOWBAR
AERIALAERIAL + GPS
FINISHER (SELF-ADHESIVE)GLOSS BLACK REAR SURROUND TRIM
SIDE MOULDINGS (TYPE)BLACK AIRBUMP SIDE PROTECTORS
WHEEL EMBELLISHER (STYLE)WITHOUT WHEEL CAP
UNDERBODY SHIELDPLAST+FOAM UNDER ENGINE PROTECT+OPTIMISED REAR
REVERSING LAMPSWITH 1 REVERSING LIGHT
INDICATORSLUMINOUS SIGNATURE
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
EXT. LOAD RETENTION RING (ATTACHMENT)TRUCK EXTERIOR LASHING RING
EXT. REARVIEW MIRROR COMP. FUNCTIONMANUAL FOLD EXTERIOR MIRROR
ENGINE BAY SOUNDPROOFINGSOUNDPROOFING UNDER BONNET + BULKHEAD + SERVO
WINDSCREEN WIPERFRONT WIPER BLADE WITH RAIN SENSOR
REAR SCREEN WIPER (OPERATION)INTERMITTENT REAR SCREEN WIPER
FRONT PANEL BLANKWITHOUT FRONT BUMPER PLUG
ROOF GLASSWITHOUT ROOF WINDOW
BUMPERSTD COLOUR-CODED FR/RR BUMPER
NUMBER PLATEWITHOUT LICENCE PLATE
LUGGAGE RACKMOUNTING WITH ROOF BARS
FRONT FOGLAMPFOG LAMPS WITH CORNERING LIGHT
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE)ELECTRIC DRIVER’S EXTERIOR MIRROR
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE)PASSENGER ELECTRIC DOOR MIRROR
SPARE WHEELSPACE-SAVING SPARE WHEEL
EXTERIOR ACCESSORIESBODY COLOUR EXTERIOR HANDLE
BUMPER TRIMMAT BLACK FR CAPPING + BLACK RR
GLASS (APPEARANCE)TINTED + DARK-TINTED RR WINDOW GLASS
WINDOW (TYPE)LAMINATED WINDSCREEN + TOUGHENED REAR SCREEN
Interior Fittings
ANTI-THEFT ALARMWITHOUT THEFT PROTECTION ALARM
REAR HEAD RESTRAINTREAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINTFRONT HEADREST ADJUSTABLE
REAR SEATSEPARATE FOLD BACK BENCH SEAT
LUGGAGE COVERSHELF
REAR SEATBELT3 REEL 3 PT REAR SAFE BELT + UNBUKLED WARNING
FRONT SEATBELTRETRACTOR ALARM DRIVER + PASS S/BELT
CLIMATE (AMBIENT TEMP)TEMPERATE COUNTRIES
CHILD LOCKELECTRIC REAR CHILD LOCK
SPEED GRADUATIONSSPEED GRADUATION IN MPH
GEAR SELECTORFLOOR GEAR CONTROL
RADIO EQUIPMENTFEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER
DRIVING POSITIONRIGHT HAND DRIVE
REMOTE CONTROLWITH REMOTE CONTROL
BOOT AND LOAD SPACE LIGHTINGAUTO BOOT LIGHT AND LOAD VOL SWITCH
DASHBOARD EQUIPMENTMID GREY DECORATION
INT. TRIM AND EQUIPMENT VARIATIONSTANDARD HANDBRAKE KNOB
MISC. INT. LAMPSLIGHTING BY LEDS
LOAD SPACE TRIMCARPET BOOT MAT+BLACK RING
INSTRUMENT PANEL (CHARACTERISTICS)LCD DIGITAL INSTRUMENT PANEL WITH SEGMENTS
LOUDSPEAKER4 FR SPEAKERS (2 TW + 2 FR)+2 RR SPEAKERS
RADIO CONTROLSDIRECT CAR RADIO CONTROL
POLLEN FILTERWITH POLLEN FILTER
PASSENGER COMPARTMENT SOUNDPROOFINGPASSENGER COMPARTMENT SOUNDPROOFING CROSSMEMBER+BULKHEAD+TUNNEL+RR WHEEL ARCH+FR FLOOR
FRONT SEAT ARMRESTFRONT SEAT CENTRAL ARMREST
COMPACT DISCWITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEMNAVIGATION 2 COLOUR SCREENS
DRIVER’S WINDOW LIFTSTANDARD ELECTRIC DRIVER’S FR WINDOW
PASSENGER’S WINDOW LIFTSTD ELEC CONTROL FRONT PASSENGER ELECTRIC WINDOW
DISPLAYDIGITAL TOUCH SCREEN
COURTESY MIRRORDRIV OCCULT+PASS OCCULT W/O LIGHT
OIL GAUGEW/O OIL LEVEL INDICATOR
FITTING REAR HEAD RESTRAINTMOUNT 3 REAR HEAD-REST
HEATING ELEMENTNON HEATED SEAT
FRONT LATERAL AIRBAGTHORAX SIDE + CURTAIN AIRBAG
PASSENGER AIRBAGWITH AIRBAG ON PASSENGER SIDE
ON-BOARD COMPUTERCOMPUTER
EQUIPMENT PACKW/O EQUIPMENT PACK
EXTERIOR REAR VIEW MIRROR (HEATED)HEATED EXTERIOR MIRROR
AIRBAG DEACTIVATIONMANUAL AIRBAG DEACTIVATION
REAR LOAD FLOORWITHOUT REAR LOAD FLOOR
STORAGE (DRIVING POSITION)W/O SETTING BOX
RADIO RECEIVERSMEG DIGITAL RADIO RECEIVER
REFRIGERATIONAUTOMATIC AIR CONDITIONING
CRUISE CONTROLREGULATOR AND SPEED LIMIT
DRIVER’S SEAT HEIGHT CONTROLPARALLEL DRV HEIGHT ADJ
INTERIOR REAR VIEW MIRRORDAY - NIGHT INTERIOR MIRROR
DRIVER AIRBAGDRIVERS AIR BAG
LOAD SPACE STORAGEW/O BOOT TIDY
TUNER RADIOMONO RADIO TUNER
EXTERIOR TEMPERATURE (SCALE)CELSIUS EXTERIOR TEMPERATURE INDICATOR
OBSTACLE DETECTION SYSTEMRR RADAR OBSTACLE DETECTOR + RR CAMERA
TRIM ADAPTATIONPLASTIC KNOB + PVC GAITER
FLOOR MATW/O CARPETMAT
RADIO FREQUENCYWESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROLCENTRAL DEAD LOCKING
STEERING WHEELLEATHER STEERINGWHEEL
AUDIO PACK AUXILIARY SOCKET1 JACK SOCKET + USB
TELEMATIC UNITWITHOUT TELEMATIC UNIT
Electrical
ALTERNATORALTERNATOR 150 AMP
BATTERYBATTERY L2 640
STARTER MOTORSTARTER MOTOR CL 4
SPECIAL LIGHTINGDAYLIGHT RUNNING LIGHTS
CEN. LOCKING REM CONTROL FREQUENCY433.92 MHZ SUPER HETERODYNE
MULTIPLEXINGECO ELECTRICAL ARCHITECTURE
BATTERY CHARGE MEASUREMENTWITHOUT BATTERY CHARGE MEASUREMENT
LIGHTING OF LAMPSAUTOMATIC SWITCHING ON OF LIGHTS
Component Manufacturers
Miscellaneous
SPECIAL SPECIFICATIONSTANDARD
MODIF. DURING MODEL YEARMINOR INDEX "06"
CONDENSER (SPECIFICATIONS)CONDENSER 19.2 DM - THICKNESS 12CM
ATMOSPHERIC CONDITIONSNORMAL ATMOSPHERE
VIN PLATEEUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
RADIO HEADPHONE SOCKETSINGLE ACCESSORY SOCKET
TRAFFIC SIDEDRIVING ON THE LEFT-HAND SIDE
SIDE IMPACTSDOOR WITHOUT REINFORCEMENT
SET OF KEYS2 HIGH FREQUENCY REMOTE CONTROL KEYS
DOOR SEALSEAL DIRT EXCLUDER
REFRIGERANTAIRCON FLUID 1234 YF
EMERGENCY EQUIPMENTW/O HELP EQUIPMENT
SLAVE CONTROL UNITBSI + COM 2008
As far as the harness is concerned, there's no separate electrical harness for the ESP system (apart from the wheel speed sensors of course). It is integrated into the main wiring harness:
(1) Main Harness, part: 1614307080, £1051.52
EdMar
x 3
Thakyou,
Build sheet informative ,
Manual fold mirrors,
they are stuck & i didnt wasnt to 'encourage' them too much incase they were power fold (some power fold need taken apart to free them)
Standard power windows,
That explains why I cant reprogram the Auto-windows :rofl2:
Is there a thread for requesting build sheets , radio codes etc ?
I used to use servicebox and other manufacturer sites,(before new stellantis system req VAT no.)
and i do a bit of diagnostic work for mates in the trade, so often forum donations are worth the time saving (previously would have jumped on servicebox etc which were chargable)
Borrowed a picoscope & quick decode of can bus, showing low priority packets getting dropped, mate says PSA cars with ABS in wheel arch prone to water ingress & any time he has arch liner out, clutch etc, he checks ABS plug, contact cleaner spray & electrical grease.
Thanks again
x 6950
Pop up any parts only requests on the Official Parts Thread to help ensure your request is not missed. Ask for a build sheet as needed, (please bear in mind this isn't intended for commercial use), but we don't mind the occasional request.
Just for reference: PSA vehicles don't need radio codes - the Head Units are all VIN-coded to the vehicle. :wink:
EdMar
x 3
Hi ,
Thanks, I was thinking Renault for radio codes, but I think newer ones are VIN coded to.
I get a few diagnostic jobs from mates in the trade, sevicebox etc wanting VAT is may the push I need to go into it in a bigger way.
In the mean time if I have any commercial related requests, I'll make the odd extra donation .
x 6950
No worries - it's the time more than anything as we have hundreds of posts to get through on the Forum each day. Staff can't provide any official technical help for Renault as they have a different system, so staff can only help with part numbers and part diagrams for Citroen, DS Autos and Peugeot. :wink:
Renault should also use VIN coding this day and age for their telematics units too.
