ZX TD injection pump
skypilot
Unread post by skypilot »
My ZX TD has the Bosch injection pump. The rod with the ball joint at each end and its bracket is missing - maybe removed by a previous owner? (This is shown in the Haynes manual, page 1-18.) Does this have any effect on the fuelling? The turbo seems to work ok, it definitely kicks in around 2,200 rpm.
Mosser
Unread post by Mosser »
If its the same bit i'm thinking of (black cylinder about 5 inches long) then its the throttle damper, its there just to stop the car being too jerkey when your in slow traffic, its just a small hydraulic damper unit to slow down the movement of the throttle and i believe some cars never had them fitted
NiSk
Unread post by NiSk »
You're not missing much - the "throttle" damper is more a pain in the *** than useful. They usually wear out after about 100k klix and just cause an annoying rattle - even if you originally had one - you're better of without it.
//NiSk
