the window switch button box on the frivers side of the citroen c5 2006 phase 2.
adiopeto
Unread post by adiopeto »
If anyone can provide perhaps a video, thecnical survive manual or a step by step guide of removing and replacing it I would be thrilled. Also, the problem is that it realy doesent like me using the windows and when I try to close them it's a battle whit the buttons, only for them to go back down afterwards.
x 2938
Re: the window switch button box on the frivers side of the citroen c5 2006 phase 2.
The switch just lifts out, prise it up at the ends with a screwdriver, then it can be dismantled and cleaned inside, the problems are usually caused by water and dust inside., Plenty available on Ebay if yours is beyond repair.
x 2007
Unread post by Stickyfinger »
A good few cars both Citroen and Pug use the same switch....
x 3298
The most likely problem is dirt on the contacts. I had this happen on my first C5 (in that some of the functions didn't work), and I managed to access the circuit board (and the rubber membrane), carefully cleaned them up, re-assembled them, and the windows worked properly after that.
adiopeto
Hell Razor5543 wrote: 27 Dec 2024, 18:32 The most likely problem is dirt on the contacts. I had this happen on my first C5 (in that some of the functions didn't work), and I managed to access the circuit board (and the rubber membrane), carefully cleaned them up, re-assembled them, and the windows worked properly after that.
started to deasemvle it anf found 2 ishues. 1 how do i remove thw button caps so i can reach the curcet board and 2 how do i conect it back. there is a cabel conector whit 3 cabels coming out of it. its white. and a black one whit a bigger bundle of cables. thanks for the help prematurely
adiopeto
Update, I managed to do everything, but I made a mistake , I put in the mirror selector for adjustments back in, whiteout the main case and now I can't remove it. Do I need a special technique or just pry it out
