citroen relay electronic immoboliser
Hi guys newbie here... First of all fantastic forum.
can anyone tell me why my immoboliser sticks on?
when the engine is cold it works fine but after a trip or when its hot it decides to play up... please please help im going out of my mind trying to locate the prob....
Sorry.... its a 2.5D swb, yr2001, the only light that stays on is the orange key shaped warning lamp on dash, (it goes out when working ok)
When lit engine turns but wont start, ive tried every key that i have including the master and i have checked for loose wires or bad earth.
The anntena and yellow box are intact and in good condition.
IF you need more i will try to tell you, thanks; vanmanic
No picture but i will try to describe it!!
it is close to the ignition and the anntena plugs into it, there is a small board inside the box about 2 inches Sq.
the wires that go in (or out?) are red, black, blue&red, yellow, blue&green, blue&white.
numbers are 46417024 198 L c150 and a bar code 46417024041
thanks again for your time on this, hope that describes it enough.
- My Cars: Current - Slightly modified 2016 Pug 308 Puretech 130 Allure
Past:
2003 - 206 GLX TU3JP & 206 SE ET3JP4
1995 - 405 Executive XU10J2
1996 - 406 GLX XU10J4R
1994 - 405 GTX XU10J2 - x 1
Well that yellow box has me stumped now.
All I can suggest is you try the forum here at
http://www.carmechanicsmag.co.uk/
There are a few Peugeot & Citroen technicians on there & a lot of very clued up diagnostic technicians too.
the yellow box is the imobiliser control unit and its coded to the module in the injection pump so it is'nt interchangeable from another van.as said above the anntena can be swapped from another van no prblem as it isnt coded.
when the fault occurs try wiggling the plug on the yellow box & see if it starts,if that doesent help i would suspect the antenna being faulty.
Hi chaps me again, after blaming every component that citroen ever made i finally have a result.
Its the connection between the immoboliser and the diesel pump. (well done wheeler nearly right) well its apparantly that what is faulty, not only that citroen want £700 squids to put it right.... S**T. anyone help PLEASE
Hi wheeler, Citroen reckon its the modu on the fuel pump thats faulty, they said thats why when it gets hot the problem starts.
(im still not convinced)
To get to the part in question they say its a 5 or 6 hour job which as you know at citroen rates bloody expensive, they say new cambelt @ £30.00 which needs doing soon anyway and the mod\pump @ £170.00 LOL
Typical italian give up at the first sign of trouble. (NO OFFENCE INTENDED)
