C4 fans by steering column keep burning
AstaFire
Unread post by AstaFire »
Hi all, the wires for the fans by the steering column on my c4 grand picasso (2008 reg, 2.0HDi, DW10QBTED4 RHJ engine code) keep burning out, i have changed the relay in the engine bay, put new fans in, but It still keeps burning out. Does anyone have a wiring diagram or any idea what's causing it to keep burning out?
Thanks in advance
x 1471
Re: C4 fans by steering column keep burning
Unread post by xantia_v6 »
Most likely the fan motor is drawing too much current. This may be due to stiff bearings, or it may be an internal short in the motor.
PaulC5
x 698
Unread post by PaulC5 »
Is the pollen filter blocked up, when was it last changed. Might also be a short in the wiring but I would expect a fuse to blow, unless one has been replaced with a high amp one.
x 6946
^^ Both these suggestions - check when the pollen filter was last changed - you'd be surprised how much crud and bugs can get in there and this restrict the air flow, so can put a strain on the blower motor.
