I currently have a fault with obd code of c1392
It has a host of lights abs, traction, hill start , spanner all in Orange
The vac pump was screaming and has been replaced along with 4 abs sensors
C1392 is calibration according to what I can sense
I’ve checked the volts on all 4 leads and are reading constant and correct
Any thoughts and how to do calibration without a computer ?
Thanks in advance
C1392
- x 6956
Re: C1392
C1392 is Electronic stability program (ESP): Not characterised
Nothing about calibration - it's a non-characterised fault. You'll get all manner of warnings when there is a fault with the system as it's responsible for everything from emergency collision braking, descent control, hill start etc, as well as the electronic handbrake and ESP / ABS functions.
Suspect areas could be any of the following - because the specific fault is uncharacterised...
- Hydraulic block ABS / ESP
- ABS/ESP ECU
- Wheel speed sensors
- Drive axles
- Steering wheel angle sensor
- Tyres
- Magnetic targets of the wheels
