Citroen c3 gearbox oil
Mazvie
Unread post by Mazvie »
I drive a Citroen c3 a5hm01 2016 automatic. Been good for two years. Recently the gear changing has become an issue. It might remain in gear one no matter how you rev the car.
Mechanic suggested l change the gearbox oil for the car. The problem is we are not sure which gearbox oil is specific to this car.
Can someone help with the gearbox oil that suits this car .
PaulC5
x 670
Re: Citroen c3 gearbox oil
Unread post by PaulC5 »
You will need to post your VIN for admin to look up your car.
Mazvie
What is a VIN. Where do I find it
x 1443
Unread post by xantia_v6 »
The VIN is the Serial number of your car. It has 17 letters and numbers. You can find it on the registration document or it can be seen through the windscreen (from outside) at the bottom left hand side.
Mazvie
My VIN
Mazvie
Greetings. May you please help with the gearbox oil type for my Citroen c3 a5hm01 auto 2016.
Someone suggested 75w-90, synthetic oil
