Hello,
I have got to grips with most of the settings on the so called 'Infotainment system', but the general screen brightness adjustment doesn't seem to be available. I understand about the 'Day' and 'Night' auto or manual switching for the Nav screen, but there is also a slider for screen brightness that is set midway and is greyed out all the time. There is a brightness slider for the HUD display brightness which works ok
I thought that maybe it is only activated in certain engine/lights/nav screen, etc configurations, but having tried most of them, it seems always to be greyed out and therefore not adjustable.
Is anyone else able to adjust this, or is it a feature that should have been activated by the garage when the car was initialised?
Many thanks for any thoughts.
Citroen c5X 2024 Screen Brightness
brianj24240
Re: Citroen c5X 2024 Screen Brightness
I have solved my own problem, apparently the screen brightness control becomes active once it is night time... well, they don't tell you that in the User manual!
Sloppysod
- x 398
Sorry I didn't see this earlier as I could have saved you some frustration. It got me wondering as well before I worked it out.brianj24240 wrote: 23 Dec 2024, 18:17Hi again,
I have solved my own problem, apparently the screen brightness control becomes active once it is night time... well, they don't tell you that in the User manual!![]()
Stu
