NAC Retrofit
This is the Connected NAV system.
Main Features: It is a fully integrated Telematics System featuring CarPlay, Android Auto, Real Time Services, Voice Commands, High-Res Display, 3D Navigation, Bluetooth Hands Free & USB. 2 versions of the system are available NAC (Navigation Audio Connectée) and RCC (Radio Couleur Connectée) or Connected Colour Radio, which does not have the Integrated Navigation or Live Services.
Para25
NAC Retrofit
Unread post by Para25 »
Apologies re-hashing an old subject but need a bit of guidance.
Peugeot 508sw 2013. Replaced Rneg2 with NAC Wave2 and configuration done for P508.
The NAC came from a 2016 2008 and I have donner chassis number.
Have set up peugeot app to doner chassis inc live services subscription, but can't get the services to load.
(Map update from peugeot gone in but firmware won't, I believe it's a license issue).
I read it might be an issue if a subscription has not been instigated on doner vehicle and if so is there a work around.
Tomas1
x 11
Re: NAC Retrofit
Unread post by Tomas1 »
If the connected services have not been activated on the donor car, you must have the VIN number of the donor car in the BSI at the time of activation.
You probably have a secured BSI and it is not possible to replace the VIN number.
Try to activate on an older car, possibly CAN2004.
Para25
Re: NAC Retrofit
Thanks on the reply, bit gutted as that was the main reason for upgrading.
So absolutely no way of any programming on the secure bsi.
Any way to tell if It has said bsi?
Tomas1
x 11
Re: NAC Retrofit
What do you mean by "It has said bsi" ?
x 1939
Re: NAC Retrofit
Unread post by Paul-R »
I think he means if there's a way to see if it has a secured BSI.
