Peugeot 5008 2018 cluster problem
Roberts R
Unread post by Roberts R »
Hi , does someone else have experienced display suddenly going dark?
It happened yesterday, then it was back on and now it doesn't turn on at all, whick is quite annoying.
I assume that the power goes to the display since the orange wrench is glowing on a startup and then disappearing when engine is running.
x 6945
Re: Peugeot 5008 2018 cluster problem
It really needs a proper diagnostic first as there may be something going on apart from the screen itself.
x 1055
Unread post by wheeler »
I see you have some trims off around it, i'm guessing you have checked the connector(s) are securely plugged in?
Tried a BSI reset yet?
