P20EE SCR NOx Catalyst Efficiency Below Threshold Adblue Urea Flashing
poratnir
Unread post by poratnir »
I got P20EE SCR NOx Catalyst Efficiency Below Threshold Adblue Urea Flashing ,
I have replaced the injector to new one - do I need to reset the computer ? how can it be done?
Is it possible there is another issue there?
x 1493
Re: P20EE SCR NOx Catalyst Efficiency Below Threshold Adblue Urea Flashing
You need to check through the live data to see why it has set the code, it is not necessarily the injector at fault.
x 6945
This fault is usually diagnosed by the dealer's diagnostics in connected server mode to check that the engine management ECU software is up to date. There is a guided diagnostic that would be done. Then the DeNOx system fault codes are reset using Diagbox via the Menu: Service action ? Emissions control circuit ? Reinitialisation of the deNOx system faults.
