206 clutch cable conversion
jsp
x 12
Unread post by jsp »
is it possible to convert the automatic adjustable one to a manual one?
Oldpug
x 94
Re: 206 clutch cable conversion
Unread post by Oldpug »
I doubt it? Why do you want to do this. If you use a genuine O/E cable, and it’s fitted correctly, it should work perfectly. Provided the clutch itself is good that is.
I mentioned O/E cable because I found many of the cheap aftermarket ones caused problems.
jsp
x 12
Even the OE cable doesnt fit. As I have a different Clutch set than oem set. It does fit, shifts but, the cable is too short.
