Adblue activated?
GORAX
x 14
Adblue activated?
Unread post by GORAX »
Hi everyone, My C4 Grand Picasso had the DPF replaced and now it's quiet. I now wanted to activate Adblue again. Encoder flashed etc. etc. Tank now shows 10 degrees at idle. Pressure is at 4 bar at idle. Is it active again? As a test, the adblue plug was unplugged to see if it gave any errors. Vehicle didn't show one but in live data it showed 0 bar with adblue pressure and with adblue temperature it showed not found. Is the coding correct now? Nox is working normally again.
GOOGLE TRANSLATE
x 6950
Re: Adblue activated?
Really hard to advise as we don't know what modifications were made in the first place to disable it.
x 1060
Unread post by wheeler »
Get the car nice & warm, watch the live data, once the exhaust temperature gets to 176 degrees C you should see the urea pressure start moving up from 4 bar to between 5 & 6 bar. If it does this then id say its working again.
GORAX
x 14
I think it works because I now got the error p2048. How should I proceed with this error? what needs to be done?
GOOGLE TRANSLATE
GORAX
x 14
I will finish here and open new topic because is new problem
GOOGLE TRANSLATE
