Partner wiring diagram
purchj
Hi again please can some one help, i am looking for a Peugeot partner 2002 wiring diagram
- x 6945
Re: Partner wiring diagram
For what sub-system? We can only assist with the odd diagram, so please be specific, i.e. power steering, injection, starting, exterior lighting etc. You will also need to provide the vehicle's VIN. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
purchj
Hi, thank you for replying.
The problem that i have is, I do not have power to the cabin heater switch or heater fan.
I might be wrong but on this car i think the power comes through the BSI, with out a wiring diagram i cant find out
Its a 2002 Partner 19d, chasses, VF7**************[VIN obfuscated, can be read by forum staff]
The large pink wire, feed ?? going to the fan switch has burent out and switch control is hard to turn
purchj
So, nobody can help me with a wiring diagram.
My plan is, i intend to run a 30amp fused wire from the battery to the heater fan.
Fit a 40amp relay from the heater switch to a 30amp fuse from the battery
The relay to be powered by the ignition switch
Cut the two large diameter wires that are powering up the fan and switch
If some one can see a problem with this plan please can you let me know
The only problem i have is what are the two small wires that run the same way as the two large ones ???
That why i need a wiring diagram
Thanks in advance if i get a reply
purchj
If anyone is interested how i go on, here it is.
Repaired the earth wire going to the heater switch by removing the old burnt out one and fitted a new wire 30amp and connector, i was able to fit the new connector on to the pin and reconnect the wiring socket over it, this wire i thought was a live, purple wire, was in fact the earth??
Ran a live wire 30amps with a fuse from the battery through the bulkhead to the red wire on the fan motor
It works ok but it will not turn off when the ignition is remove, so next thing to do is fit a relay into the live wire from the battery and use one of the spare fuse slots in the engine bay fuse box that only works when the ignition is turned on
purchj
Last Post from me, sorry to truble you all.
Found a free ignition fuse slot when the ignition is ON in the engine fuse box, that was not being used.
Soldered a 10 amp wire to a fuse spades after grinding the plastic off
Drilled and secured the relay to the inner wheel arch,
Cut the 30amp wire from the 30 amp fuse to the heater motor and fitted to the relay
Fitted the 10 amp wire from the fuse box to the relay, and the last relay connector to earth
Now the heater fan turns off when the ignition is turned off
