Does anyone have the official method of replaceing the exhaust gas temperature sender that is fitted just before the turbo on the Blue Hdi 2.0 ? Can't see it; can just about feel the connecter over the top of the engine but all in all looks a serious pig of a job. Any tips welcome. I am not entirely sure if it does need changing ---- there is no fault code coming up, but a real time read out when driving shows just a flat line with no change regardless of whether the engine was under load, coasting etc.
As I have a new one for comparison, does anyone have the relevant terminal numbers at the ECU plug in order I may test the resistance of the existing one ?
Thanks, Mike.
C4 Picasso B78 2.0 Blue Hdi Access to exhaust temperature sender
onthecut
- x 7
