Hello everyone,
does anyone have instructions on how to change the gearbox oil on a 2015 Citroen C4 Grand Picasso automatic?
Gearbox oil change
GORAX
- x 14
Gearbox oil change
GOOGLE TRANSLATE
GORAX
- x 14
GORAX
- x 14
Re: Gearbox oil change
I haven't had the opportunity to switch yet but would you recommend it or has anyone done it before? I can't find anything official that it should be done at all...
GOOGLE TRANSLATE
- x 6945
No! - Do not use that video - it is only for piloted manual gearboxes, not 6 Speed proper automatic with a torque converter! That is the incorrect video and incorrect oil - so I am removing the post as it could cause damage if followed on a fully automatic gearbox.
You have an AM6 gearbox and the oil change procedure is here for this gearbox:
AM6 Automatic Gearbox Drain & Refill
GORAX
- x 14
GORAX
- x 14
Had the change done today. The instructions were very helpful. I used Liqui Moly 1800 ATF as oil. Runs without problems!
- Attachments
GOOGLE TRANSLATE
