Peugeot 206+ 5 doors 1.4i 5MT ECM VALEO V34.3 15.10.2012
AlexeiCMN
Need help. Engine computer does not communicate. there is a fault code U1208 in ABS/ESP ..... Engine speed enters emergency mode 1500 RPM. Engine & ABS/ESP & STOP warning lights are on...... i can't find SERVICE MANUAL for Peugeot 206+ anywhere. with ECM VALEO V34.3
AlexeiCMN
Re: Peugeot 206+ 5 doors 1.4i 5MT ECM VALEO V34.3 15.10.2012
help me find exact electrical connection diagrams for my car.
PaulC5
- x 685
If you give your car VIN admin might be able to help with a wiring diagram.
This topic on U1208 is worth reading viewtopic.php?t=64597
AlexeiCMN
AlexeiCMN
under the hood in BCM B5. 12 volts do not come to fuse 15 and 2. I have shaken all the wiring under the hood and in the cabin. I can't figure it out. Who gives the order to give them electricity?
- x 6945
Here's the ESP / ABS Diagram:
With the exception of the wiring codes, most of the component codes are indexed here:
PSA Electrical Diagrams - Wiring & Symbols Codes Index
AlexeiCMN
Solved this problem. Changed ecm Valeo v34.3. And the car came to life.
