Does my van have PAT fluid? VIN below.
Philip1972
Unread post by Philip1972 »
Hello all.
I am stumped about the Eolys fluid business. I have searched the posts here and also Google.
I have a 2017 Peugeot Boxer, 2.0 BlueHdi 160 bhp. I am being advised that I should check the PAT fluid level, however, I have no idea where the tank is on the van.
I have the Adblue tank, and have even been under the van looking for another tank, but nothing there!
There is no mention in the handbook about PAT/Eolys fluid, or DPF additive, anywhere (I have read the manual about 3 times tonight! Very unlike a normal man!!)
I thought I had read somewhere that not all the engines have PAT fluid, but I would be very grateful if someone could confirm either way.
VIN number is VF3**************[VIN obfuscated, can be read by forum staff]
Many thanks
x 1488
Re: Does my van have PAT fluid? VIN below.
Yes it has DPF additive. The tank appears to be on the nearside next to the fuel tank - often they are under a plastic cover. It will tell you when it thinks it's low (no level) and it generally errs on the side of caution so I wouldn't worry too much about it.
Philip1972
Thank you Richard, much appreciated.
earlsgate
x 6
Unread post by earlsgate »
My Boxer Eolys fluid showed half full at 80k miles. The tank itself is under the passenger step when you need to acess
Cliff
Unread post by Cliff »
Hi , been reading about pat fluid for Peugeots ,
How do I find out if my vehicle needs it as I can’t find another bottle to top up , cheers Cliff
x 1943
Unread post by Paul-R »
What year is it? What engine is in it?
