Hi guys! Im having problem with my C5 II (2006 2.0 petrol).
Had occasional power steering faulty with stiff steering which can disappear in 5 minutes to 2 days.
Things i have done:
-Bleed the system trough reservoir
-Checked fluid level and topped it to appropriate level
-Checked wiring going to pump
-Battery voltage and fuse is fine
Im have minor leak in rear left sphere.
Any ideas what to check/do?
C5 Power steering faulty
- x 6947
Re: C5 Power steering faulty
If you have a leaky sphere you'll probably be getting air back in the system, so bleeding it will serve little purpose until you've sorted the leak.
