Hi All,
I'm sure this has been asked many times before, but to be honest it's confusing the hell out of me. I've just bought a 2012 C4 Picasso and want to add bluetooth support to it without changing the existing stereo. I know I can use a radio transmitter, but the sound quality isn't great. The car I have also has reverse sensors, which I believe will stop working if I put an aftermarket headunit in ? Where do I start please ?
Thanks,
Andy
2012 Citroen C4 Picasso Bluetooth
- x 6950
Re: 2012 Citroen C4 Picasso Bluetooth
You can't add bluetooth to an RD4 except with the aftermarket options you have already mentioned that use a transmitter type interface. There are plenty of cheap options out there on Amazon.
Replacing the Head unit with an RD45 requires the RD45 unit, a microphone installation, replacement MFD display of the correct version and software type and of course programming with Diagbox. That's just the way it is with a 12 year old car - but bear in mind that these head units were designed years before production, so the tech is even older.
shtu
- x 81
One of this style of device will work, and tbh I'd not look to spend more on the RD4,kronosone wrote: 03 Dec 2024, 06:14I've just bought a 2012 C4 Picasso and want to add bluetooth support to it without changing the existing stereo.
https://www.ebay.co.uk/itm/203709861230
https://www.ebay.co.uk/itm/304534846319
Both are fundamentally the same thing, one is marginally easier to fit.
If you want a better-integrated solution you could look to change to the similar RD45, though if you don't already have a Diagbox tool, it may be better value overall to look at an Android head unit instead.
