2.0 HDi - P0088 & P1166 FIXED!
steveclv
x 40
Unread post by steveclv »
I put this at the end of one of my other threads but just wanted to post this here in case others search for the same problem.
My 2009 C5 X7 with a 2.0 HDi 138 260,000km kept throwing an ECL every time I accelerated hard and when we scanned the errors we found P0088 and P1166 which all related to high fuel pressure. I also had an "Antipollution Faulty" message that briefly appeared on the dash.
When I checked the live sensor data for Fuel Pressure I could see it spiking with a very uneven pattern and when I booted it hard to cause the error, the fuel pressure spiked at around 2000 bar.
We diagnosed this as most probably being the Fuel Pressure Regulator that is mounted with 2 screws behind the High Pressure Fuel Pump in one of the most awkward positions to get at - in fact I wasn't able to get at it so had to let my local garage do it (just 1 hr labour) and I opted for a genuine PSA replacement (ouch!) rather than my €45 Aliexpress one - I have no doubt it would have worked as it was identical but I don't want to have to do it again. I have seen other people saying that they have been able to do it themselves.
After installing it, I again ran live data and saw a high flat line with high frequency spikes +-10bar, exactly as it should be, and the pressure maxed out at 1550bar.
The car felt smoother but not as quick as before and the fuel consumption does appear to be lower - obviously it was being overfuelled with the failing regulator.
I hope this helps someone in the future as the Antipollution error message is extremely confusing :)
MixerFistit
x 14
Re: 2.0 HDi - P0088 & P1166 FIXED!
Unread post by MixerFistit »
About to do this on a 307CC.
Do you remember the price and part? It doesn't happen on mine often but tends to pop up on an occasional long motorway run. Would've thought the Welsh hilly A roads would be more likely to set it off than a motorway cruise tbh
307 CC 2.0 HDI
Sold/dead
Mk1 Dispatch 06 Face lift - 2.0 HDI - RHZ (sold)
2x xsara picasso 1.6 HDi
2x mk1 C4 Pic and a mk1 C4 GP
1x mk2 C4 Pic
C8 2.2.hdi (6 seat Exc) van/can
207cc 1.6 hdi (project)
PaulC5
x 682
Unread post by PaulC5 »
You could try PF Jones for a pressure regulator. It will help if you find out the fuel pump type/model by looking at it for a label. On our C5 I had to use a mirror and torch and then took a photo so I could enlarge the image. Different cars and even model years can have various pumps so possibly one for a C5 may not fit your car. https://www.pfjones.co.uk/fuel-pumps-an ... alves.html
MixerFistit
x 14
Good shout, I'll go digging. I haven't had a good look at the pump on this yet, last time I looked at a 2.0 it was on an old RHZ engine on the Expert with a leaky bosch CP1. I'm guessing this one is a little more advanced
307 CC 2.0 HDI
Sold/dead
1x mk2 C4 Pic
