RT3 Map Query
This is the RT3 unit and was made by Magneti Marelli
The RT3 was available in a few different hardware versions, the later ones supporting MP3 playback. These units had an optical connection to the Display Screen.
deniz arda
RT3 Map Query
Unread post by deniz arda »
I have 2006 citroen c4 with rt3 navigation system incase i can't use it, when i want to open navigation it says "please insert the navigation cd" but i don't have the correct cd form can you send it to my denizardagocbak@gmail.com mail adress and i can write it to an empty cd.
Thanks!
Reason: Moved to new thread - Off Topic
x 6957
Re: RT3 Map Query
@deniz arda: we do NOT supply navigation maps. RT3 systems require the navigation CD to be present for navigation to work.
https://citroen.navigation.com/product/ ... enEMEA/GBP
deniz arda
Re: RT3 Map Query
Okay, thanks
x 1942
Re: RT3 Map Query
Unread post by Paul-R »
@deniz arda
PM sent to you which might be of some help.
x 6957
Re: RT3 Map Query
I should add, that I don't believe there are any maps for Turkey on this system.
