No sound on ng4
pasamonis
No sound on ng4
Hi, i have a problem with my ng4, there is no sound on radio, after factory reset sound will appear but then i turn of engine and turn on again sound disappears, after factory reset sound appears again and will be until i turn of engine, can anyone help that to do?
- x 6945
Re: No sound on ng4
How old is the car battery?
Have you made any modifications?
HAs the unit started to restart itself?
pasamonis
Re: No sound on ng4
No modifications was made, unit doesnt restart by itself, just then i turn on engine there is no sound, and then i do factory reset sounds apear and will be until i turn of engine,i dont know how old is battery, i bought car 3 days ago (peugeot 3008, 2012years)
- x 6945
Re: No sound on ng4
1) I would first get the battery tested - (it may be starting the car but if older than 5 years it will have lost capacity to hold a charge).
2) If you have replaced the vehicle battery make sure you do a BSI Reset / Battery Disconnect / Reconnect Procedure
This can often cure electrical faults and should be followed before disconnecting the car battery to avoid electrical problems.
It would be helpful to have your VIN so I can check to se if you have the Services Module fitted or anything else that may be affecting this. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
pasamonis
Re: No sound on ng4
