Hi all.
I torqued up the front hub nut on Peugeot 5008 mk1 to 325NM , now noticed that the locking pin and cap are quite loose when fitted on the hub nut...
Is it really 325NM for the hub nut? Or smth else is a miss here
Peugeot 5008 mk1 hub nut torque
amazighman
Re: Peugeot 5008 mk1 hub nut torque
Sorted.
But is torque 325nm correct?
- x 1496
Sounds right, I usually work on 240ft lb. The R clip and nut cover are always loose.
perrye
- (Donor 2026)
- x 10
Yes it is
