Problem = rear left door will not open
Blipper on key not working/falling apart/no power even with new battery
Button is down and will not lift, I have not "forced" it yet
Handle moves but does not open the door (no "bite" ??-disconnected ??)
Obviously the door cards cannot be removed as they are trapped by the seals........so what to do ?
Xantia rear door stuck
- x 1996
- x 1459
Re: Xantia rear door stuck
If it is a S1 Xantia, the lock and unlock signals come from the IR sensor board above the rear view mirror, and you can apply power to the wires to send an unlock signal.
- x 1996
- x 1996
