Hello,
I've recently bought a C3 Connexion 2011, but the maps are 2011 and the software needs updating on an RNEG screen. Most of what I found online required a USB to update, that's not an option in my car.
I understand that I'll need an SD card for this so I have ordered a 32GB one to use.
The version my car is currently using is rneg_D_R29a_R29.01, and from what I have seen I need to install rneg_R50b_R50.03, but I'm not sure if that is the latest version.
I haven't been able to find a usable software download link. What is the latest software version I can install and is there a link to download it?
Also, I have found somewhere online to purchase Europe 2024 maps SD card for £50, but is the a download link I can use to install this myself?
If anyone can provide these download links and also some step by step instructions on how to install them into my car, I would really appreciate it.
Also, is there somewhere I can keep an eye on for when new software and map versions are available?
Thank you in advance,
Saul.
C3 RNEG Software and Map Update.
- x 6957
Re: C3 RNEG Software and Map Update.
All the information regarding upgrading the firmware is in the appropriate MyWay / RNED Forum here and why I've moved your Post to this Forum.
MyWay (RNEG) Firmware Upgrade Procedure
rneg_R50b_R50.03 is the last update available.
This system is not updated by USB, that is only for other telematics systems like the RT6 / RNEG2 and later systems. Your MyWay system is updated vi the SD card slot, so make sure you have a spare one of sufficient capacity and do not use the one for your maps!
You purchase navigation maps officially from Citroen's Navigation site:
https://citroen.navigation.com/home/en_ ... enEMEA/GBP
