Hi all,
Taking my Blingo to France in 3 weeks, and can't work out how to get the headlamps to dip the other way, or at least get them so that they do not blind oncoming French people.[:p]
Its the Mk2 Berlingo with the big plastic lenses, the lenses are clear and have none of the usual patterns where you would stick tape or those deflecter things.
Anyone got any ideas?
Driving abroad - Blingo
I've used the stick on deflector lenses (the type that redirects the beam) on the Xantia and they worked well. If I understand your problem it's that you are not sure where on the lense to position the deflector. In that case can you not do it by trial and error in the dark so that you can assess the changes ? I guess the problem with thiat will be the adhesive though.
Mark
Mark
- Panjandrum
Jon,
This site has a fitting guide for the beam benders showing wher to fit these to clear lenses
http://www.saxonind.co.uk/Beambenderfitguide.pdf
Last time I went to the Loire valley for a week, the stick on benders I had had lying unopened for a while fell off. I guess I should have cleaned the glass better. The best I could find in the car was the sticky back from a carpark ticket. Painted with a black biro and cut in half, this lasted fine despite the rain.
Fablon sounds much more durable and not much more expensive.
- My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1 - x 72
- Contact:
Beam masks for the Xantia are a complicated shape - each mask cuts off the top right and the bottom left areas, with the two pieces joined by a narrow strip. Both headlamps are slightly different. When I got my Xantia in '98, I bought a Lucas kit for the model. I stuck the two silhouettes onto a piece of tin plate and cut them to shape. I need new masks three times a year, so by putting the templates on a sheet of Fablon and cutting with a Stanley knife, I quickly make up a set.
