front brake calipers vibration
memine
Unread post by memine »
My front calipers vibrate when driving if i touch brake pedal lightly the noise stops i have put new disk and pads on but still does it so if i grease the pins and pads alls well for a week then its back so i bought new slide pins but unsure which way round the slide pins go as in on each side it has a steel plain pin and a pin and rubber does any body know does the pin with the rubber go on top or bottom of caliper ? cheers
PaulC5
x 570
Re: front brake calipers vibration
Unread post by PaulC5 »
What year is your C3 ?
Mihael_M
x 34
Unread post by Mihael_M »
This is how it behaves when anti-roll bars are not good .
Nr. 4
https://catalogs.ssg.asia/citroen/?lang ... I9PQ%3D%3D
memine
PaulC5 wrote: 04 Nov 2024, 21:28 What year is your c3
2014 mate
memine
Mihael_M wrote: 05 Nov 2024, 05:11 This is how it behaves when anti-roll bars are not good .
Nr. 4
drop links are new or are you talking about the rubber bushings in the roll bar ? cheers
PaulC5
x 570
This link has a video that shows how to replace the brake pads so you can see the slide pins.
Mihael_M
x 34
memine wrote: 06 Nov 2024, 18:50 drop links are new or are you talking about the rubber bushings in the roll bar ? cheers
No I mean anti-roll bar link , is that what you call it drop links ?
memine
Mihael_M wrote: 06 Nov 2024, 20:45
the drop links are new buddy but i might just change them again just to see , cheers
memine
PaulC5 wrote: 06 Nov 2024, 20:25 This link has a video that shows how to replace the brake pads so you can see the slide pins.
[thanks for that ]
