Hello,
Armed with diagbox (9,91) I thought I'd dig around the settings and see if I coud find the one for the mirrors folding automaticly when you lock the car. I've dug as much as it felt safe but no luck. Does anyone know where this setting is in DiagBox or if it is a misprint in the manual where it says this is the way to do it? I don't get when this setting should be so hard to find if it exists.
Thanks!
Stop side mirros folding when locked
pi14
- x 8
Re: Stop side mirros folding when locked
Hi!
Once I did it in my C5 X7 year 2017 so I am not sure if this instruction below will be useful. I switched off automatic folding side mirrors while locking doors. Additionally, this will be my translation from polish. So go to:
BSI ->
BSI Service ->
BSI Telecoding ->
BSI Manual Telecoding ->
BSI Vehicle configuration ->
BSI Safety features - Doors and Covers - Mechanical support components
switched off automatic folding of side mirros - this option I found in the 'Key' Settings where it was 'Yes' and I changed to 'No'
Hope this wolud help.
Best
Przemek
BSI ->
BSI Service ->
BSI Telecoding ->
Best
Przemek
pc4
Thanks for the info. Unfortunally I couldn't find the menus you mention.pi14 wrote: 03 Nov 2024, 16:15 Hi!
Once I did it in my C5 X7 year 2017 so I am not sure if this instruction below will be useful...
- x 1060
Not sure about this model but most PSA cars this function is switched on/off using the mirror button on the door? Doesent usually need any diagnostics.
Normally set the mirror adjustment setting to the middle with the ignition on & pull the button back for a few secons till you hear a beep or chime/
citroC5
- x 20
I tried it with my 2010 C5 X7 and it didn't work, unfortunately.wheeler wrote: 04 Nov 2024, 17:22 Not sure about this model but most PSA cars this function is switched on/off using the mirror button on the door? Doesent usually need any diagnostics.
- x 6950
...but as per your other thread concerning the incorrect control pad - it will work perfectly - so long as you have the correct control pad to start with.... you have the wrong part fitted.
