The window has been stuck fully up for 9 months.
I finally got around to investigating the issue today.
I am a capable mechanic, not a newbie, but even I have bad days.
I have power to the regulator motor connector, both positive and negative pins, when activating the door switch.
I have a good earth on the harness connector earth pin.
Its a 6 pin connector with 5 wires connected.
I swapped the regulator motor assembly thinking that was the issue, but nope.
If i take the new regulator motor and stick it on the passenger side, it works as expected, so I know my new regulator motor is good.
But now i suspect the existing regulator is okay, maybe I have a wiring fault somewhere?
All fuses are checked as good.
I am stumped....anyone want to chime in on this one?
