Hi all,
Have any of you ever replaced the mechanism for a Xsara Picasso driver's window? The motor works, but the window is jammed. I'm guessing regulator and cable needed.
I hate working inside doors. I'm not good at it. Any tips and tricks?
It also needs 2 lower arms, but I'll happily do them myself..
Thanks!
Xsara Picasso electric windows
Mr_Pink82
Re: Xsara Picasso electric windows
Hey I have a similar problem. My window is half open and won't close. What did you do to fix your window?
- x 6957
If the regulator wire has rusted and snapped, you'll need to take the door card off and investigate to confirm this, but I certainly wouldn't operate the window motor as it can cause the wiring to start tangling if it is the regulator wire that's gone.
No tips unfortunately as that's something I don't have the patience for and too awkward without being a contortionist.
