Hello everyone,
I own a Citroën Jumpy 1.6 (90 HP) and I've been experiencing some issues that have led to error codes P0192 and P0299. Here’s a quick rundown of my situation:
Symptoms:
The vehicle goes into limp mode when driving up steep hills.
I get the error code P0192, which indicates a low input from the fuel rail pressure sensor.
Sometimes, I also receive the error code P0299, indicating a turbocharger underboost condition.
I can resume driving after clearing the codes, but the problem returns when I encounter a heavy load, especially uphill.
Recent Maintenance:
I’ve already replaced the fuel filter in hopes of resolving the issue, but the problem persists.
Any suggestions?
Citroën Jumpy 1.6 (90 HP) Error Codes P0192 and P0299 – Seeking Help
Hodorious
- x 6945
Re: Citroën Jumpy 1.6 (90 HP) Error Codes P0192 and P0299 – Seeking Help
I'll need your VIN to determine exactly which vehicle and engine management system you have as the codes have different meanings depending on the system. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Hodorious
Hi Marc,GiveMeABreak wrote: 30 Oct 2024, 10:05 I'll need your VIN to determine exactly which vehicle and engine management system you have as the codes have different meanings depending on the system. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Here is my VIN: VF7**************[VIN obfuscated, can be read by forum staff]
- x 6945
Ok, so you have the DV6UTED4 with Bosch Engine Management System. Here are the fault descriptors to help with troubleshooting:
| Fault Code: | P0192 |
| Description of Fault: |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P0299 |
| Symptoms: |
| Suspect Areas: |
Hodorious
UPDATE:
Took my car to my local garage and they solved the P0192 by cleaning the pins on the sensor (they where very dirty).
However the car still doesnt pull like it used to, when in nuteral I cant get it over 3000rpm.
No error codes. What could be the couse?
PaulC5
- x 686
You could do with looking at live data. The MAP pressure sensor could be bunged up with oil so its values are not changing much. On our C5 I occasionally got P0299 and found the sensor bunged up so put on a new one and it accelerates quicker. P0299 has since come back now and again though but does not put on the engine management light and it never did but I have not looked to see if it is bunged up again.
- x 6945
It's likely a protection mechanism, so revs are limited when idling / in neutral.Hodorious wrote: 01 Nov 2024, 07:49 UPDATE:
Hodorious
I see.
My issue now is the cars lacks of power. I drive the same 4km steep hill every day and earlier I was able to do about 95km/h uphill while now it peaks at around 80km/h and I have to use a lower gear than usual...
