Citroen Relay Timing belt interval
Conchur
Unread post by Conchur »
Hi All
Can anyone tell me what the interval is for a timing belt and water pump on a 2019 Citroen relay with the 2.0 blue hdi 110 engine
x 6954
Re: Citroen Relay Timing belt interval
You'll need to provide your VIN. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Conchur
x 6954
Timing Kit and Coolant Pump 10 years or 150k KMs, whichever is soonest.
Conchur
Perfect thank you
perfidus
x 6
Unread post by perfidus »
I don't want to start a new topic, does anyone knows the service interval info for the timing chain and tensioner (in the cylinder head between the camshafts)? Same 2.0Blue HDI engine with 160HP (DW10FUC). I think I heard some tapping noises from the top of the engine at idle and lower revs under 2000rpm. The tapping is intermittent.
Those who don't know history are destined to repeat it!
x 1479
Unlikely there's a specified interval for the chain - it's supposed to last the life of the engine...but I suppose if it breaks that will be the life of the engine! If there's any doubt then it would probably be worth changing it.
Dharam
New User
Unread post by Dharam »
I have the same question please for my van...
