The timing belt tensioner on my AX has let go. I've got a couple of question before I start attacking it with a spanner:
1. I've got a TU3M engine as fitted to the GT injection, does anyone know if this is the alloy or iron block?
2. The tensioner went as I tried to start the car - is the engine of the non-interference type or is there a chance of valves meeting pistons?
3. Changing the timing belt and tensioner doesn't look too difficult apart form the restricted space - is there anything else I should be aware of? The Haynes is less than clear when it refers to fabricating tools and specialist citroen tools. Do I hang the weight off the bar and tioghten it until the bar is horizontal?
thanks
dave
Timing belt and tensioner on an AX GT
AndersDK
If the engine has been running with a broken (or slipping) timing belt, I doubt you'll have any fun with that engine ever again.
Before you fork out money for any spares, do a simple check :
remove timing belt, remove spark plugs, then carefully and slowly crank engine by hand.
If it clearly reaches resistance against turning - and HAS BEEN ALLOWED TURNING - then bye-bye engine [xx(]
Otherwise :
Go by your logic and fantasy, when manuals calls out for special tools.
In this case it's widely known, that a timing belt this lenght is just exactly tensioned right, if with normal fingers force, you can twist the belt 90deg at it's longest run.
Otherwise :
