Can anyone explain to me how voice commands work on the C3 Origin PureTech (01/2024)?
Works via Bluetooth, via USB cable or just via the Internet?
When I connect via the cable and press the button, the phrase asking what I want appears on the display, but when I speak, the voice responds with the message "oops, an error has occurred".
Thanks.
New C3 Origin 1.2 PureTech 83
- x 6945
Re: New C3 Origin 1.2 PureTech 83
None of those!
There are 2 options depending on vehicle options and / or connected equipment.
Voice commands are built into the Head Unit and will work for navigation and telephone and playing music. It's activated by pressing the voice control button on the steering wheel once quickly.
If you are connecting an iPhone and have CarPlay, then hold the voice command button in for a bit longer and Siri will kick in. Or if you iPhone is already connected to the system, just saying 'Siri' or 'Hey Siri' will also launch it. Bear in mind that Siri may need an internet connection depending on what you are wanting to do.
I can't advise on Android Auto as I don't use it, but I'd imagine it is similar to the iPhone using CarPlay.
6511cts
Thanks for the answer.
In my case, I use Android Auto.
Can anyone help me?
Can anyone help me?
6511cts
My display is a 7", without navigation maps installed.
I use Google Maps, with my Phone connected via USB cable.
- x 6945
Ok, so you will likely have the RCC Head Unit, which should still be CarPlay / Android Auto enabled.
According to Google:
https://support.google.com/androidauto/ ... 0Auto%20in,.
For more info see here:To control Android Auto in compatible cars, you can talk to Google. Simply follow these steps:
Choose one of these ways to start: Say 'Hey Google', press and hold the voice command button on your steering wheel, or select the microphone.
Wait until you hear the beep.
Say what you'd like to do.
6511cts
Thank you for your attention.
In my vehicle, voice commands only work if the cell phone is connected via a USB cable and the mobile data service is active.
Compliments
Compliments
- x 6945
That’s correct you will need to have the phone connected via a cable to use the service.
