The drivers side door is dropping on my wife's 207cc, 2008, 11000 miles, so well used. The latch is catching the door metal as the door has droped and I can see this on the shut lines as well. I can see any adjustment on the hinges. Has anyone worked on this before? Any help appreciated.
Regards,
Colin.
207cc 1.6l petrol, door mis-alighned
Colin2206
- x 19
Huskyxantia
- x 908
Re: 207cc 1.6l petrol, door mis-alighned
There should be some toqure bolts which can be lossend off while the car door is open & jacked up with a trolly jack, the jack should just take the slack of the amount of drop , then tighten the bolts , lower the jack & this should of done the trick . If not then the pins in the hinges need renewing , dont leave it or you could lose the door at its worst case .
Husky.
Colin2206
- x 19
Thank you for the reply, sorry for being so late coming back to you.
I'll give this a try, starting with the door side mounting.
