Good afternoon all,
My mother in law has a 2013 Citroen C3 Picasso, the blower for the interior heater has started intermittently not working.
It either works when she first starts the car and then may go off during a journey or will not be working when she sets off but may spring into life when it feels like it, or it may just work perfectly.
I've removed the lower panel on the centre console and checked the wiring connecter for the blower it shows no signs of damage or overheating as this is a known problem.
I don't know if this year/model the blower is controlled by a resistor module/speed controller or by the bcm?
Does anyone have any ideas of things to check?
2013 C3 Picasso Intermittent Blower
Mihael_M
- x 37
Re: 2013 C3 Picasso Intermittent Blower
You probably have this : https://www.autodoc.co.uk/ridex/13628571
cthompson
Thought I'd update this, she took it to a local auto electrician whilst I was away on holiday and they found a loose wiring plug in.behind the head unit.
They reconnected it and the blower has been working perfectly ever since, they only charged her £54 too so not so bad.
Chris.
Chris.
