2011 peugeot 308 music player stuck on ''silent''
This section is for information and posts relating to Audio Head Units, and Navigation Systems
jarlax
Unread post by jarlax »
I've been dealing with this issue for about a month now. I found a temporary fix: I remove the entire front panel and the music player itself. There are two small empty slots where the main cable connects to the player. I use a small copper wire, placing each end into these empty slots, which somehow resolves the 'silent' issue. However, the problem returns after a while when I turn off the engine.
Does anyone have suggestions for a more permanent fix?
