Berlingo K9 wiire through the bulkhead
Runeelling
Unread post by Runeelling »
Hi.
Berlingo 2020 i want to get a 16mm2 cable from the battery to the boot. i have a left hand drive car. Is there a easy way to do this?
the steering colum grommet is so low in this car.
x 6955
Re: Berlingo K9 wiire through the bulkhead
I strongly advise against that. Whatever it is you want power for, consider using the internal fuse box and a ‘piggy back’ fuse for the correct amps you need.
Runeelling
Its for a spare lithium battery in the boot. For my van/camper. And i am going to use a victron dcdc charger. And this needs a 16mm2 cable .
x 6955
Ok, well they do provide different electric harnesses for PSA vehicles specifically for charging a battery in a caravan for example - but these are for the towing electrical harnesses that are properly fitted with special fuse box, so can't advise on this.
x 1056
Unread post by wheeler »
Is there a grommet on the bulkhead where the clutch hydraulic pipe would go through on a RHD model?
Be very careful if going through the bulkhead, I have seen many a BSI destroyed buy this due to water ingress with poorly positioned/sealed wire entry's.
Have you considered running the cable underneath the car along the floorpan?
