Citroen Synergie Gearbox?
markallinson
Unread post by markallinson »
Does the Synergie share its gearbox with any other models? I.E. could a Xantia TD box slot into a Synergie TD?
A neighbour has a Synergie with a faulty box and I have notice a few cheap Xantias so maybe a source of a replacement box? Theres been no joy with breakers for Synergie gearboxes.
TheWorker
Unread post by TheWorker »
coincidently i was just working on a 1.9 td synergie just yesterday and the box LOOKS similar to the ones the xantia 2.1 and HDIs. i say looks because its got the same cable shifter instead of the small link bars
001272
Unread post by 001272 »
hi mate i was jus wnderin u wouldnt happen to have a copy of the owners manual for synergie wud ya???
TheWorker
no,sorry. i sed i was working on one,i dont acually own one
Dave Bamber
Unread post by Dave Bamber »
The Synergie box is similar to the larger Citroen vans, so unfortunatly the Xantia box doesn't fit.
The synergie uses the larger ML and ML5 type gearboxes.
You'll find the gearbox that you need in Peugeot 806 TD, Citroen Dispatch van TD and Peugeot Expert TD van.
(Info lifted from a post reply by Jon on 21/5/2004)
