I am hoping to get some advice on a 206 that has a aftermarket drivers seat fitted. I want to fit a resistor to bypass the airbag warning light on the dash.
There are 2 connector plugs from the loom. One is a green 3 pin and the other is a White 2 pin which I assume is for the airbag. Do I need to fit 2 resistors one for each plug? and do I need a diag tool to reset everything after?
Anybody ever done this? I would welcome any advice
206 Airbag warning light
- x 6957
Re: 206 Airbag warning light
Sorry, we can't provide this type of advice as it involves safety systems.
I suggest you refit the original seat, as without it, I suspect your insurance company will need to be informed that you don't have a functioning seat airbag.
