Citroen Relay (Jumper) 2.0 Blue HDI 160HP from 2016, how to identify the alternator type and D+ connection
perfidus
x 6
Unread post by perfidus »
Does anyone have a schematic for the battery/alternator/ignition part of the vehicle in the subject?
Where do I find in the vehicle configuration (see this post: viewtopic.php?p=807071#p807071) what is the type (amperage) of the alternator fitted?
The case:
For my campervan based on a 2016 model Relay, I have some issues with the leisure battery charging and I want to make some modifications to the onboard electrical installation. I'm a professional electrician so first thing that I noticed on the leisure battery system was the small cross section of the cables that connects the battery bank to the charger/inverter, too small for a 2,4KWh battery pack (about 80Amps is the maximum power to the inverter and cables are 10 sqmm). The previous owner who made the conversion also used minimum components and the system is not optimised, so I'm planning an upgrade.
First thing to do is to install a battery monitor unit (a shunt with V/A meter - coulomb-meter) to verify the charging capacity of the leisure bank (who is supposed to be 2 x100Ah). This will come with a new set of battery cables with a proper section.
The second step is to replace the manual switch that puts the leisure batteries in parallel with vehicle battery, I know this setup is problematic and also can damage the alternator on the road. I only used it once at night and I noticed how the headlights were dimmed briefly when the fridge compressor is starting :D.
Since then I prefer to charge only from the solar panels but this isn't enough sometimes, especially in fall and winter.
A voltage relay would be cheaper but doesn't eliminate the risk of alternator overloading, so I will buy a DC-DC converter which is controlled by the D+ terminal of the alternator.
For this I will need acces to this D+ terminal circuit, find how it's tied to the ignition switch and if it's possible, find it inside the cabin for a clean install.
Thanks!
Those who don't know history are destined to repeat it!
x 6945
Re: Citroen Relay (Jumper) 2.0 Blue HDI 160HP from 2016, how to identify the alternator type and D+ connection
perfidus wrote: 03 Oct 2024, 08:30 Does anyone have a schematic for the battery/alternator/ignition part of the vehicle in the subject?
1) Sorry, no.
2) By requesting a build sheet (which I will provide for you shortly, here):
Vehicle Characteristics
Vehicle FamilyRELAY III
AS/RP N°14483
Warranty Start Date02/09/2016
Engine serial number10 DYZZ 4012521
OPBJ0ZI
BERe3*2007/46*0046*11
General Information
PRODUCT TYPECOMMERCIAL VEHICLE
COMMERCIAL MARQUE/COMPONENT TYPECITROEN
VEHICLE FAMILYRELAY III
SILHOUETTEEXTENDED VAN H3 TYPE 16H
TRIM LEVELSTANDARD
ENGINEDW10FUC FAP DIESEL
TRANSMISSIONBVM6
PAINT TYPENON-METALLIC PAINT
BODY COLOUREWP - BANQUISE WHITE PAINT
INTERIOR TRIM TYPECLOTH DARKO + TWILL "35"
UPHOLSTERY COLOUR"FX"
GEARBOX (CHARACTERISTICS)BVM6 MLGUC14
CONVERSION GUIDANCEWITHOUT CONVERSION
DEFINITION TO FOLLOWMID-LIFE
ENGINE (TYPE)EW/DW
TRIM LEVELSTANDARD
STEERINGVARIABLE POWER STEERING
SPEEDOMETER DRIVETACHO TORQUE 18X14
Fuel supply-Engine
FUELDIESEL GRADE DA/DE/DE+
ENGINE (TYPE)EW/DW
CAPACITY2000 CM3
VEHICLE EMISSIONS STANDARD (TYPE APPROVAL)DEPOLLUTION EURO6 (HOMOLOGATION)
CRANKCASE GAS CIRCUIT HEATINGWITH HEATER CASING GAS CIRCUIT
PARTICLE FILTERWITH PARTICLE EMISSION FILTER
STOP AND STARTWITHOUT STOP AND START
Gearbox Transmission
TRANSMISSIONBVM6
FINAL DRIVE RATIOCP 14 X 75
WHEEL (TYPE)STEEL WHEELS
INFLATION PRESSURE LOSS INDICATORWITHOUT TYRE DEFLATION INDICATOR
GEARBOX TYPEMLGU6 MANUAL GEARBOX
Suspension-Steering-Brakes
TRACTION CONTROLANTISLIPPING
SUSPENSIONDOUBLE-LEAF RR HEAVY DUTY SUSPENSION
SUSPENSION (ARCHITECTURE TYPE)METAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEMELECTRONIC STABILITY PROGRAM
EMERGENCY BRAKING ASSISTANCEWITH EMERGENCY BRAKING ASSISTANCE
Body Fittings
TOWBARWITHOUT TOWBAR
AERIALLONG ROOF AERIAL
SKIPW/O FLAT HAMPER
CABINCLOSED SINGLE CAB
CHASSISSTANDARD CHASSIS
PAYLOADHEAVY PAYLOAD 16Q
SIDE MOULDINGS (TYPE)LATERAL PROTECTOR MASS TINTED
EXHAUST TAILPIPELEFT-HAND SIDE
INDICATORSLONG VEHICLE SIGNALLING LIGHT
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTIONEXT MIRROR MANUAL-FOLD BACK
OPENING OF MOVING PANELDOOR OPENING AT 270 DEGREES
WINDSCREEN WIPERFRONT WIPER BLADE W/O RAIN SENSOR
HEADLAMP WIPERW/O HEADLAMP WIPER
SIDE LOAD DOORRH SLIDING SIDE METAL DOOR
BUMPERDYED FRONT/REAR BUMPER
MUDFLAPWITHOUT MUDGUARD
ROOFSTANDARD ROOF PNL
LUGGAGE RACKWITHOUT ROOF BARS
FRONT FOGLAMPNO FRONT FOG LIGHTS
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE)PASSENGER ELECTRIC DOOR MIRROR
SPARE WHEEL MOUNTINGSTANDARD SPARE-WHEEL CARRIER
WHEEL EMBELLISHER (TYPE)WHEEL TRIM WITHOUT CUSTOMER CHOICE
BODY CONVERSIONWITHOUT
REAR WINDOW (TYPE)WITHOUT REAR WINDOW
GLASS (APPEARANCE)TINTED
WINDOW (TYPE)LAM W/SCREEN + SIDE + RR TOUGHENED
SIDE WINDOW (COMM. VEH. ONLY)WITHOUT SIDE WINDOW
ROW 3 SIDE WINDOWWITHOUT SIDE WINDOW 3ND ROW
HANDS FREE ACCESS AND STARTINGNO ACCES AND HANDSFREE STARTING
Interior Fittings
ANTI-THEFT ALARMWITHOUT THEFT PROTECTION ALARM
REAR SEATWITHOUT REAR SEAT POSITION
SUPPLEMENTARY SEATWITHOUT SUPPLEMENTARY SEAT POSITN
CABIN SEAT2 PLACES PASSENGER BENCH
CIRCUIT BREAKERWITHOUT BATTERY CUT-OFF
CLIMATE (AMBIENT TEMP)COLD COUNTRIES
SPEED GRADUATIONSSPEED GRADUATION IN KM/H
DRIVING POSITIONLEFT-HAND DRIVE
REMOTE CONTROLREMOTE CONTROL ASSEMBLY
ADDITIONAL HEATINGWITHOUT ADDITIONNAL HEATING
FRONT HEAD RESTRAINT (STYLE)OPEN FRONT HEAD RESTRAINT
TIMERWITHOUT TACHOGRAPH
RADIO CONTROLSWITHOUT REMOTE RADIO CONTROL
SIDE DOOR CONTROL MECHANISMNON-MOTORIZED, ELECTRIC LOCKING SIDE DOOR
FRONT PASSENGER SEAT HEIGHT CONTROLWITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT CONTROLDRIVER SEAT MANUAL CONTROL
FRONT PASSENGER SEAT CONTROLPASSENGER FRT SEAT MANUAL CNTR
FRONT SEATWITH DRIVER’S SEAT
DRIVER SEAT ADJUSTMENTDRIVER’S LUMBAR ADJUSTMENT
FRONT PASSENGER SEAT ADJUSTMENTWITHOUT FRONT PASSENGER’S SEAT ADJUSTMENT
FRONT SEAT ARMRESTFITTING WITH DRIVER’S FRONT ARMREST
STOWAGE BINWITHOUT SETTING BOX
SATELLITE NAVIGATION SYSTEMWITHOUT NAVIGATION SYSTEM
TRAFFIC INFORMATION READERWITHOUT LATERAL TRAJECTORY MONITORING
MISC. INT. ACCESSORYDOCUMENT HOLDER TABLE
HEATING ELEMENTNON HEATED SEAT
FRONT LATERAL AIRBAGWITHOUT FRONT SIDE AIRBAG
PASSENGER AIRBAGNO PASSENGER AIRBAG
ADDITIONAL AIR CONDITIONINGWITHOUT ADDITIONAL AIR CONDITIONING
EXTERIOR REAR VIEW MIRROR (HEATED)HEATED DOOR MIRROR
REAR MOVING PANEL2 REAR HINGED METAL DOORS
COURTESY LAMPFR+RE DOORS CONT - FR+RE INTERIOR LAMP
FRONT SEAT GUARDREMOVABLE CAB PROTECTION PANEL
RADIO RECEIVER4 SPEAKERS WITHOUT RADIO RECEIVER
REFRIGERATIONSINGLE AIR CONDITIONING
CRUISE CONTROLREGULATOR AND SPEED LIMIT
DRIVER’S SEAT HEIGHT CONTROLFR + RR DRIVER HEIGHT ADJ
REAR VIEW MIRRORSSTANDARD REAR VISION
DRIVER AIRBAGDRIVERS AIR BAG
INTERIOR PROTECTIONMID-HEIGHT INTERIOR WALLS PROTECTOR
OBSTACLE DETECTION SYSTEMWITHOUT OBSTACLE DETECTOR
LOCKING CONTROLNORMAL + AUTOMATIC LOCKING
STEERING WHEELSTANDARD STEERING WHEEL
PASSENGER SEAT PACKBENCHSEAT WITH 3-POINT CENTRAL BELT
SUPPLEMENTARY HEATERWITHOUT ADDITIONAL HEATING
AUDIO PACK AUXILIARY SOCKETWITHOUT AUDIO PACK AUXILIARY SOCKET
Electrical
BATTERY (FITTING)UPPER BATTERY
STARTER MOTORCLASS 6 STARTER MOTOR
SPECIAL LIGHTINGFRONT DAY RUNNING LIGHT (DRL)
Miscellaneous
SPECIAL SPECIFICATIONSTANDARD
RADIO HEADPHONE SOCKETWITH ACCESSORIES SOCKET
PLATEWITHOUT PLATFORM FLOOR
SET OF KEYS1 HIGH FREQUENCY REMOTE CONTROL KEY+1 MAIN KEY ONLY
COUNTRY ADAPTATIONWITHOUT
EMERGENCY EQUIPMENTW/O HELP EQUIPMENT
SURFACE CONDITIONSGOOD TERRAIN
You'll have to do some looking up on the part number for further details as the specifications are not specified by Citroen. Your vehicle has a Class 22 Mitsubishi Alternator (A003TV0281ZE), part: 9818962280, so is likely to be 210 or 220 A
perfidus
x 6
Yes it's 220Amps, all replacements for OEM part indicates the same as you mentioned. This is enough for a decent DC to DC (or B2B) charger rated at 30Amps current draw from main battery B+/alternator circuit. With 200Ah leisure battery, 6-7 hours of driving is enough for a full charge in absence of solar.
I'll try to find schematics with the Diagbox software I have, but last time I try it was a real pain...
x 6945
You won't get a schematic from Diagbox, sorry, they are not contained in that software in any case - you will have to pay for access to these from Citroen's website via the technical documentation, via a time-based subscription. I don't have this particular vehicle in my resources, otherwise I would have provided it for you.
x 1055
Unread post by wheeler »
Im not sure if you are overthinking this, a voltage sensing relay is the way to go i’d say for a split charging system. Some charging systems on modern vehicles can throw a hissy fit if you tap into the alternator IND wiring. This is how i have set up my own camper & several others in my family.
I would also leave the manual switch in as a back up to. My first VSR (cheapo one) failed whilst i was heading to the Isle of Skye (i have a dual voltmeter display). Luckily both the batteries are under the bonnet so was able to run a jump lead from + to + as a temp solution but as soon as i came back i fitted an isolator switch that i can use to override the VSR should it ever fail again.
perfidus
x 6
I think D+ is something else, different from IND. I understand D+ should be linked to IGN+ and is a low current input that activate the voltage regulator circuit. It should tell the B2B charger that the engine is running. Some people do not recommend VSR on Euro6 vehicles, charging voltage varies from 12 to 14,7-15V and VSR gets disconected during the trip.
perfidus
x 6
After some internet resources, +D and IND is the same thing:
L/D+/IND/16/15/61/R/1: (Warning Light) This type of connection is for the warning light circuit. This circuit must have a 12V supply on ignition which should go out when the alternator begins to charge.
perfidus
x 6
After some research on my own, I found an interesting manual from Fiat, addressing conversions and upfittings. This is what I found:
So I must search pin 2 from the C036 L1A connector, and use it for split charging control as suggested in the figure below:
No need to directly connect with the D+ terminal from alternator, if I have this connector.
perfidus
x 6
There are news to this topic and I thought I should share.
For the moment I'll keep the D+ terminal unconnected to the DC-DC converter, because my van charging system is a classic one (not smart, I have no battery management module fitted to the battery) and converter knows by reading the voltage when to disconnect/stop charging the house battery. The starter battery begins charging the auxiliary battery when its voltage reaches 13.2V & 15s and stops charging when the voltage drops to 12.7V.
I performed this test recommended in the DC-DC converter manual:
The automobile alternator may be a smart alternator or a traditional alternator. The connection method of a smart alternator or a traditional alternator depends on its parameters. Before installing the battery charger, read the user manual of the vehicle or consult the vehicle supplier to determine the type of alternator and ensure that the alternator power does not exceed 720W with the output current within the range of 75A to 100A.
In addition, you can use a multimeter by yourself to measure the alternator to determine the type of alternator.
1. Locate your main vehicle battery or the starter battery.
2. Start the engine. Ensure all any fans, radio, lights, and others are turned off.
3. Take a voltage reading across the main vehicle battery.
4. Leave the engine run for around 5 or 10 minutes, and repeat Step 3.
Readings around 14.4V DC indicates you most likely have a traditional alternator. If your readings are around 12.5-13.5V, you most likely have a smart alternator
